13 Users Online (11 Members):
Forums >> Community >> Newbies >> Export an Image shortcut help.
0 Posts No Rating |
Ok so I know in order to export an image in revit you have to go to file>Export>Images and Anamations>Image, this is all fine and good. But can someone help with a shortcut or a file that can be imported to revit to give a shortcut to this process? So that you can just type (like EI for export image)? Or anything of the sort just to save some time when you have to export a few views. I have looked into it but looks a little above my understanding please help.
Learn to use your HELP.
Keyboard Shortcuts
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-39D549F2-75EE-4C06-8B6A-3DADE1FBEF59
0 Posts No Rating |
Ya I know the obvious but that command isnt listen in the shortcuts If you had looked and not desired to just give a higher than thou are responce you would have know this. I would have expected a site moderator to give a little more of a positive and reserched responce.
If you had read that help, you would have seen this sub topic.
Add Keyboard Shortcuts
http://help.autodesk.com/view/RVT/2016/ENU/?guid=GUID-81EF5A21-F562-43A2-A816-109915C82B01
0 Posts No Rating |
Ok so it seams ther is some mis-communications. The command " Export Image" (the export image that you find by going to File>Export>Images and Animations>Image) Is "not" listed as a command in the list of commands in Keyboard shortcuts. I am trying to figure out if there is a way to write a command that i can by way of "import" at the bottom left of Keyboard Shortcuts, import to the list of commands so i can add a keystroke like "EI" to export an image. If the command is there what is it listed under because i cant find it. All i seam to find is importing images and exporting dwg files.
Does this do it?
0 Posts No Rating |
Um I think the format is differnt but i was thumbing throught the list of shortkuts and actually found the command it is listed as just "Image" not export image. and was able to very easaly ad the shortcut i was looking for. Wow i feel really dumb . Thank you for your time and help.
0 Posts No Rating |
I don't think you were dumb at all. Your question and the solution was exactly what I was looking for. And I agree with you about the moderator.
Image export |
Sat, Oct 24, 2009 at 6:25:00 PM
Incorrect Image Export Size |
Mon, Apr 12, 2010 at 3:18:51 AM
Exported Keyboard Shortcut file is .xml format - can't open in Excel |
Fri, Jan 13, 2012 at 11:41:37 AM
HELP! I just rendered an Image and it wont export or save! |
Fri, Oct 14, 2011 at 9:59:04 AM
Capture Rendering/Export Image |
Wed, Aug 15, 2007 at 10:34:26 AM
