Forums >> Revit Building >> Technical Support >> Rotate in 3d
Tue, Jan 15, 2019 at 9:25:44 AM | Rotate in 3d
1bchristian
Revit 2017 - I just created my first solid from a profile. I have attached what I created. I need to rotate it 90 deg in the z axis. Can this be done in Revit. IF so how would I do it. - Thanks Byron
Tue, Jan 15, 2019 at 10:24:12 AM | Rotate in 3d
1bchristian
Also - Is an extrusion solid?
Tue, Jan 15, 2019 at 11:01:45 AM | Rotate in 3d
1bchristian
Revit 2017 - Why can't I get the capstone to be solid?
Tue, Jan 15, 2019 at 1:20:21 PM | Rotate in 3d
Redo your extrusion placing the profile on a different axis (work plane) and extruding it perpindicular to that plane.
Extrusions can be solids or transparent materials.  You need a solid to host a void.
In your last image, almost everything is transparent ... something wrong with your sttings for the view - not the capstone.
ROTATE ELEMENT
Mon, May 16, 2011 at 8:15:08 AM
3d rotate
Fri, Sep 28, 2018 at 7:16:26 AM
Component rotate
Tue, Feb 8, 2011 at 10:55:46 AM
Rotate drawings
Sun, Apr 18, 2010 at 4:43:56 PM
How to rotate family componenent? Example Dryer
Thu, Jul 14, 2005 at 2:28:39 PM
Page generation time: 0.4199
