Forums >> Revit Building >> Technical Support >> finish a 3d detail
Mon, Jan 7, 2019 at 1:29:16 PM | finish a 3d detail
1bchristian
Revit 2017 - I have attached a 3d view that I am attempting to add a parapet cap to the wall. I don't seem to be able to draw in 3d any suggestions how I should apporach this.
Mon, Jan 7, 2019 at 1:59:13 PM | finish a 3d detail
Archtank
@Ibchristian, Make a profile of the cap and use that profile in the wall sweep. I always use that for parapet copings.
Mon, Jan 7, 2019 at 2:24:00 PM | finish a 3d detail
1bchristian
Archtank - I have gotten this far on the attached file - How do I get it to follow the slope of the wall. Thank you - Byron
Mon, Jan 7, 2019 at 2:39:09 PM | finish a 3d detail
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-E1A36DCB-C629-44BE-9400-2D02D13CF7F4
Mon, Jan 7, 2019 at 3:05:11 PM | finish a 3d detail
1bchristian
I understand how to do a sweep when creating a family. But How do I add a sweep with a sloping wall top. Outside of creating a family. Thanks Byron
Tue, Jan 8, 2019 at 8:07:55 AM | finish a 3d detail
It is the same process but in your case, it is done in the project - wall sweep.
Tue, Jan 8, 2019 at 8:24:40 AM | finish a 3d detail
1bchristian
WWHub - I apologize but I do not understand what you mean by Project -Sweep - Thanks Byron
Tue, Jan 8, 2019 at 8:58:48 AM | finish a 3d detail
Watch this video...
http://help.autodesk.com/view/RVT/2016/ENU/?caas=caas%2Fscreencast%2FMain%2FDetails%2F2be67117-18fe-4241-9a76-75fcf7859ba7.html
Tue, Jan 8, 2019 at 10:12:37 AM | finish a 3d detail
1bchristian
excellent video I have attached what I have. Can the capp be trimmed back to show part of the wall top? IF so How would you trim it? Thanks Byron
Tue, Jan 8, 2019 at 10:13:58 AM | finish a 3d detail
1bchristian
Sorry Forgot to attach
Tue, Jan 8, 2019 at 10:19:20 AM | finish a 3d detail
#11
Edit the path.
Tue, Jan 8, 2019 at 10:42:07 AM | finish a 3d detail
#12
1bchristian
Thank you for all the help. - Byron
a question about detail levels..i guess
Thu, Oct 14, 2010 at 2:04:03 PM
Detail view
Fri, Jul 30, 2010 at 1:23:38 PM
Column disappers in detail view
Mon, Jan 12, 2009 at 9:35:19 AM
Hiding finish line of wall in plan
Wed, Apr 1, 2015 at 7:04:50 AM
Color Schemes in Finish Plans
Tue, Jul 26, 2011 at 12:56:15 AM
Page generation time: 1.1243
