32 Users Online (30 Members):
Forums >> Revit Structure >> Technical Support >> Hidden line of metal deck floor in section.
I've created a metal deck profile for a floor to actually portray 2x6 framing with sheathing over it, so when I cut a section perpendicular to the framing direction it'll show the 2x framing. It worked great, however, when I cut the other direction I see a dashed and solid line that I believe is intended to show the thickness of the "metal deck" you're cutting through (solid - on top) and thickness beyond (dashed - on bottom). How do I manipulate where those lines shows up, or ideally how to get rid of them alltogether? I've looked in all the settings I can think of but don't see anything relating to the thickness lines.
Maybe it's using the visibility setting for 'hidden' in the element catagory ? Either object style or view visibility graphics settings.
Metal Deck profile question |
Thu, Jun 1, 2017 at 11:16:20 PM
Metal Structural Deck on Floor |
Tue, Jul 12, 2005 at 10:06:29 AM
1 1/2" Metal Deck Visibility |
Tue, May 13, 2008 at 11:40:33 PM
Metal Deck |
Mon, Jan 16, 2012 at 6:25:01 PM
Metal Deck Diaphram |
Thu, Jan 4, 2007 at 11:27:05 AM
