Forums >> Revit Building >> Technical Support >> Why do revit stairs still suck
Sat, Dec 22, 2018 at 12:34:36 PM | Why do revit stairs still suck
johnfin
You would think after 19 years revit would do decent stairs. I have been using version 2019 and they still are a pain. I have a 7 story building, first floor is 21'4 and the others are 10'-8". So I watched the a video on stairs and they drew the first flight and then selected multi story and the rest of the levels and the stairs and railings went to hell. So then I created the 6 flights using one and multi level feature. Only one intermediate on each level showed up so I have to create all of those but I guess the first question is how to edit the landings on each level that it created on multi level feature. Seems that the whole 6 levels are one item and I cant edit it. HELP
Sat, Dec 22, 2018 at 5:57:25 PM | Why do revit stairs still suck
John....
Multilevel stairs are for levels that are all the same.  I have done a lot of hotels with no problems.  In hotels, the first level is always higher than all of the rest.  So one stair for the first level and a multilevel for the rest. Handrails have to be worked on a bit but mine worked.  One on the first level and then the multilevel.
Never had a problem with the intermediate landing either.  Maybe a corruption in your view or file caused that.
Wrapping stairs
Thu, Aug 12, 2010 at 5:27:02 PM
Handrails at Curved Stairs
Mon, Sep 1, 2008 at 1:43:04 PM
stairs not dotted above
Fri, Feb 17, 2012 at 1:44:46 PM
Spiral Stairs around a Central Post
Sat, Apr 16, 2011 at 9:27:29 AM
Stairs will not appear in 3d, or in render.
Tue, Oct 20, 2009 at 4:53:56 PM
Page generation time: 2.3226
