Forums >> Workflow & Implementation >> API & Third Party Apps >> Revit to Ifc to Third Party BIM Viewer
Tue, Dec 11, 2018 at 11:30:03 AM | Revit to Ifc to Third Party BIM Viewer
JoFl
Hi,
I've recently been asked to export a file to IFC for use in an construction management app. When I test the IFC file in the autodesk viewer it looks fine, however when they import it to their system, the materials and linework are invisible and it is very difficult to see on screen, Just a bunch of ghostly white faces. I don't have access to their system. So far the best result in the autodesk viewer is IFC 2X3.
Any idea of things to check/ test/ threads to read etc?
Full disclousre: I'm very new to IFC exporting, i'm reasonably familiar with revit however its not my main software, we are just testing the workflow.
Thank you
Jo
Edited on: Tue, Dec 11, 2018 at 11:31:09 AM
Tue, Dec 11, 2018 at 12:36:03 PM | Revit to Ifc to Third Party BIM Viewer
I can't help much but I suggest you remember this.  IFC requires both ends - sending and receiving - to work correctly.  Some platforms work better with some than others.
Create Your Own BIM Tool in Minutes with bimU.io Viewer API
Thu, Sep 24, 2020 at 5:51:51 PM
Revit 3d model viewer for third party?
Tue, Dec 8, 2009 at 11:39:21 AM
bimU.io Viewer - Free online BIM model viewer for you and for everyone!
Sun, Nov 10, 2019 at 8:37:04 PM
Revit IFC export and NavisWorks 2009
Tue, Nov 18, 2008 at 11:15:34 AM
Revit Import IFC Options not working?
Tue, May 24, 2011 at 2:28:22 AM
Page generation time: 2.0151
