Forums >> Workflow & Implementation >> Worksets >> Revit content library
Mon, Dec 10, 2018 at 9:37:58 AM | Revit content library
ishimwesimon
I am having a struggle starting a new Revit project as I can't find any template file (either metric or imperial). I have even tried to uninstall the content library and reinstall them again but still I can't access any template or library in my Revit. Passing trough C:/program files/Autodesk/ Revit 2016 I can't find anything named as Library or Template. Can you please help me?
Mon, Dec 10, 2018 at 10:28:32 AM | Revit content library
The location (path) of your tempate files is set under the Revit R dropdown and after setting this, they are available to your projects.  This is all normally set during the install but you may not have done that correctly, especially if you use network libraries.  This setting is machine specific.
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-71E2636A-BCBC-4950-ADDD-2FB5D8CB829E
Edited on: Mon, Dec 10, 2018 at 10:30:59 AM
Best third party content library?
Thu, Dec 1, 2016 at 11:10:29 AM
Revit content library so slowww..
Fri, Sep 2, 2011 at 11:09:57 AM
Revit Family Content
Mon, Jun 3, 2019 at 3:14:21 PM
managing revit content library
Thu, May 3, 2018 at 8:37:26 AM
Australian Content Library
Tue, Sep 4, 2007 at 12:23:01 PM
Page generation time: 1.7245
