Forums >> Revit Building >> Technical Support >> edit curtain mullion join
Fri, Dec 7, 2018 at 8:32:43 AM | edit curtain mullion join
NStamal
how can i edit the join profile of curtain wall mulliion?
for my project i am using curtain wall as wood framed wall. and i need to show frame joins, but i can not change the join profile. check out the attachments. the blue lines are how i want it to show,,, is therer any way or workaround for this ? .. i really need help ,,
Fri, Dec 7, 2018 at 3:19:26 PM | edit curtain mullion join
What you are in dicating would be a rounded profile.  Did you use that profile?  I never have so I don't know if even that will show what you want.
Fri, Dec 7, 2018 at 4:02:48 PM | edit curtain mullion join
NStamal
well, i've tried circuler profile,, but at the joining they don't join as i want. see the joining in attatchment
Sat, Dec 8, 2018 at 8:12:03 AM | edit curtain mullion join
I did not think they would but still I was not sure.  If you would use in-place families instead of the CW muillons, you could probably get them to join like you want.
mullion join at angled mullion 2017
Sat, Oct 21, 2017 at 11:53:54 AM
Mullion Will not Join IF Mullion is Less Wide than Tall
Tue, May 19, 2015 at 11:03:13 PM
Generic Model Join to Curtain Wall Mullion?
Mon, May 23, 2016 at 9:47:31 PM
Mullion Join Glitch - Adding Curtain Grid Breaks
Thu, May 14, 2015 at 4:18:02 PM
corner join
Tue, Mar 14, 2006 at 3:52:38 AM
Page generation time: 0.5188
