Forums >> Revit Building >> Technical Support >> revit precision in schedules
Wed, Dec 5, 2018 at 4:32:25 AM | revit precision in schedules
mihaela
Hello,
i have this issue with the schedules:93.01+12.53 for revit is 105.55 instead of 105.54.
how can i force revit to add the rounded areas and forget about its precision?
i already tried to increase the precision - in the project settings  tab and decrease it back to 2 in the schedule format but its not working.
thank you
Wed, Dec 5, 2018 at 5:34:41 AM | revit precision in schedules
tim123
4 Stars: 19 Votes
Revit returns the actual values for accuracy.  Increase the precision in the schedule units to display it more accurately.
For example, the actual figures might be 93.014 and 12.533.  The first is rounded to 93.01 and the second as 12.53, which is correct.  The added value is 105.54.  You're asking Revit to return an incorrect value.
Wed, Dec 5, 2018 at 8:02:00 AM | revit precision in schedules
mihaela
yes, otherwise the client- would think the architect is stupid and cannot make simple sums.
if revit is so great that we can do alot of things with it, why would i use excel and compose the layout- the plan of an apartment and the areas with  other software?
Wed, Dec 5, 2018 at 8:28:39 AM | revit precision in schedules
tim123
4 Stars: 19 Votes
Well, I'm not sure why you would use Excel for that.  You will have the same problem in Excel unless you use the incorrect values.  Column B in the attachment shows the same figure as column A, but rounded to 2 places.  It returns the same results as Revit.
Setting precision for exporting to cad
Mon, Mar 12, 2012 at 10:43:34 AM
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
multiple schedules
Tue, May 1, 2012 at 1:04:42 PM
Schedules for Information In Schedules HAHA
Mon, Feb 13, 2012 at 12:08:12 PM
Schedules on multiple sheets
Thu, Apr 27, 2006 at 11:01:59 PM
Page generation time: 3.1860
