Forums >> Revit Building >> Technical Support >> Level Problems
Mon, Jun 5, 2006 at 11:12:06 AM | Level Problems
deh1966
Having problems with Levels. They are not showing up on any of my elevation or section views (and yes Levels are checked in all views in VG). I can set walls and other objects to my levels i have, but no way to change my level heights. Any Ideas.
Mon, Jun 5, 2006 at 4:12:11 PM | RE: Level Problems
vdogg
My guess would be that your levels are outside of the crop region of the views. Try expanding the crop region, and see if you can find them.. Once you do, you can right click on the level and reset to 3-d extents.
Mon, Jun 5, 2006 at 4:37:18 PM | RE: Level Problems
hisdirt
5 Stars: 5 Votes
Else something that tends to fool us often - check the 'hide views at scales corser than...' option under the view properties. We find that they default at hiding at 1:50 - which means that if your view is 1:100 then they wont appear. Just a thought!
Mon, Jun 5, 2006 at 5:10:34 PM | RE: Level Problems
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Check out by blog http://revitrants.blogspot.com/ This is mentioned in the FAQ's.
Rendering Problems
Wed, Jun 18, 2008 at 6:48:29 AM
12
Revit 2009: Creating customs Level Head: Problems with lineweight (line styles)
Thu, Jul 17, 2008 at 8:09:45 AM
create new "level" or duplicate w/ detailing?
Tue, Jan 17, 2006 at 4:06:24 PM
Move a level without deleting objects on that level
Tue, Jul 4, 2017 at 5:20:23 AM
Problems with linked files and interior elevations
Wed, Aug 3, 2011 at 7:59:52 AM
Page generation time: 0.5254
