15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Stairs with Winders
3 Posts No Rating |
I am having difficulty creating this type of staircase. The staircase is basically rectangular in plan, but it has 3 winder steps at the bottom and 3 at the top.
Whatever I try I keep getting the error message below:
"Stairs require no less than two boundaries (chains of one or more Boundary Lines)."
I'm using Boundary and Riser lines, I've tried using spiral risers but with no joy as the staircase is rectangular.
I am relatively new to Revit so it is most likely "user Error" but it's quite frustrating as there are no help topics on this type of staircase.
3 Posts No Rating |
I think I've sorted this now - I was trying to put a boundary all the way round the stairs, then filling in the risers, I've now just put the boundaries along the rh and lh sides, and put riser lines top and bottom and this seems to have solved it.
I'm not sure why putting riser lines on the boundaries worked - it doesn't seem to make sense?
Winders At bottom of stairs? |
Tue, Nov 20, 2012 at 6:49:18 AM
stair winder |
Tue, Jul 29, 2014 at 10:09:27 PM
Winders at top (or bottom) of stair |
Mon, Nov 26, 2012 at 10:33:40 AM
Concrete Stairs with winder |
Fri, May 30, 2014 at 7:27:58 AM
Winding Stairs |
Wed, Feb 1, 2006 at 5:54:58 PM
