Forums >> General Discussion >> Revit Project Management >> Relative coordinates
Wed, Nov 7, 2018 at 2:57:19 AM | Relative coordinates
koleman
Hi,
i have a strange problem and i can not fix it.
I have project base point with different coordinate than relative coordinates; i would like "move" the relative system in order to have both points in the same position.
When i try to relocate the project the relative coordinates system moves as well..
Any help?
I´m using Revit 2019
Wed, Nov 7, 2018 at 4:02:59 AM | Relative coordinates
koleman
Apparently i found a solution.
When you right click on the project point, than you can "move to origin".
Shared Coordinates Published Incorrectly
Mon, Jan 11, 2016 at 6:44:07 PM
Revit Exports DWG Sheet to 0,0,0 not correct coordinates.
Thu, Feb 23, 2012 at 9:43:34 AM
Relative coordinates in Revit
Tue, Sep 7, 2010 at 3:34:33 PM
Relative Levels and AHD
Wed, Oct 26, 2005 at 1:00:26 AM
specify coordinates at a point
Tue, Oct 4, 2005 at 12:56:17 AM
Page generation time: 0.1958
