13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> floor
0 Posts No Rating |
Greeting,
im trying to delete a floor but revit gives and error : "the top of the wall is lower than the base of the wall"
any suggestions...!
This can happen when a wall is attached to the level you are deleting. Have Revit show you the offending element so you can ghange either the top or bottom settings.
Detach the wall from the floor first. You may find that you need to adjust the wall first.
0 Posts No Rating |
got it, wall was attached to floor,
thanks for you...
Ground Floor info. appearing on Second Floor |
Thu, Jun 9, 2016 at 2:24:40 PM
floor sketching |
Tue, Aug 26, 2008 at 3:35:49 PM
(Dumb question) Can't see first floor when in second floor view [Revit 2015] |
Thu, Jul 16, 2015 at 6:11:13 PM
First floor slab or ground floor ceiling? |
Fri, Aug 30, 2013 at 7:41:03 AM
RAC 2010 Structural Floor V Floor - Whats the difference |
Tue, Jul 27, 2010 at 8:35:33 AM
