Forums >> Revit Building >> Technical Support >> Sloped wall - mass in place - profile line level
Thu, Oct 18, 2018 at 4:32:54 AM | Sloped wall - mass in place - profile line level
Benbord82
Good morning,
I have created a sloped wall with mass in place that I created with 2 lines on different floors. Now I need to change the level of one of the lines (and hence change the level where sloped wall ends) but when I edit in place mass and then click again to edit profile. Line gets highlighted but I am able to move it only horizontaly not vertically. I have found some treads online saying that I should be able to edit a work plane but no such option is available anywhere when I am editing the line. Is it possible to change the level of the line from work plane defined as level to plane defined by reference plane or do I need to delete the wall and create a new one every time I try to change the level?
Thank you.
Ben
Thu, Oct 18, 2018 at 8:55:41 AM | Sloped wall - mass in place - profile line level
Benbord82
Ok. I found the answer on my own. It's really silly. When you edit in-place the mass select in this mode the line and simply move it to desired level. Make sure you don't click on the plane and do not edit the profile because this will allow you to move the line only along the current plane. Simple as that.
How to edit a curtain wall grid in a curved and sloped surface
Wed, Dec 18, 2013 at 3:40:40 PM
Brick Pattern on In-Place-Mass is Lignter than on Wall
Sat, Mar 19, 2016 at 11:31:56 PM
Sweeping Solid In-Place Mass
Tue, Apr 27, 2010 at 3:30:38 AM
Edit profile on a sloped wall
Fri, May 25, 2012 at 11:56:52 AM
Sloped terrain and sloped foundation wall
Thu, Sep 3, 2009 at 1:57:36 PM
Page generation time: 3.4799
