Forums >> Revit Building >> Technical Support >> Hiding edges of extrusion in my plant component
Wed, Oct 17, 2018 at 9:45:33 PM | Hiding edges of extrusion in my plant component
bitslap
Hi,
I have a plant component that uses an extrusion with a material to get its colour. The point of doing it this way is that I previously used fill regions with about 20 visibility boxes for different colours, whereas now I can create a material of any colour for each plant.  I still nest the detail component for centrepoint and lineweights of trees etc.
The problem I am having with the extrusion is that I cannot hide the edges (to look like 'Show Edges' is off, or an invisible fill region boundary) of only the plants.  There is no invisible line option, or option to turn off the edge without hiding the entire extrusion.  I have tried creating 'empty' line patterns to no success.
I can do this with the linework tool but don't want to manually hide all plant outlines
Attached image demonstrates the fine black line on each circle that I am trying to hide.  Any help appreciated.
Thu, Oct 18, 2018 at 12:15:31 AM | Hiding edges of extrusion in my plant component
bitslap
I got dynamo to find these edges but I don't think I can change their style without knowing python.
Any help on changing edge line styles with dynamo appreciated.
Hiding the edges of a topographic surface
Mon, Nov 3, 2008 at 10:44:15 AM
Placing 2D Plant symbols onto Plant Schedule ?
Thu, Oct 25, 2007 at 6:01:44 PM
How to create void extrusion running on 2 different planes on furniture???
Mon, Aug 29, 2011 at 8:22:33 AM
HIDING FLOOR EDGES ON WALLS
Fri, May 24, 2019 at 4:00:10 AM
Family - edit Extrusion
Mon, Jul 18, 2016 at 5:16:12 AM
Page generation time: 0.8467
