Forums >> Revit Building >> Technical Support >> Building units as RVT Links- Wall Joins
Wed, Oct 10, 2018 at 8:30:40 AM | Building units as RVT Links- Wall Joins
samuelajay89
Hi All,
Im using Revit 2017. Since my firm is trying to step into Revit- I have been experimenting possible ways to model and work with repeating building units (in a condo for example). I dont want answers to how to do this in other ways (model groups, etc) since that would be another post. So, while i was trying the units as a seperate file which is linked in- I came across one problem:
Since the units walls are another file, graphically the wall doesnt 'join' with the exterior walls. Refer images below (sample simple test models). Images show the seperate unit file, and the linked in model and zoomed in wall join.
Is there anythin other way to make the walls appear joined, other than masking regions?
Thanks in advance for any inputs.
Wed, Oct 10, 2018 at 2:17:39 PM | Building units as RVT Links- Wall Joins
None that I see using your process.
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
WALL JOINS BETWEEN LINKED rvt FILES, IMPOSSIBLE???
Wed, Aug 15, 2007 at 12:23:06 PM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
I hate the Revit Automatic Wall joins
Thu, Oct 25, 2007 at 9:59:44 AM
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Page generation time: 0.7036
