Forums >> Revit Building >> Technical Support >> Fill Pattern
Sun, Jun 4, 2006 at 12:49:15 PM | Fill Pattern
djlandreneau
Hi All, I am trying to import a fill pattern, Cultured Stone Carolina Ledgestone 184, and when I do the pattern is nothing more than solid black. I downloaded the pattern from the Fill Patterns portion of RevitCity. DJ
Sun, Jun 4, 2006 at 1:35:25 PM | RE: Fill Pattern
Dgodfrey
4 Stars: 4 Votes
you will need to change the scale under surface pattern materials-model. i think 24 is the scale that works for those patterns.
Sun, Jun 4, 2006 at 1:49:58 PM | RE: Fill Pattern
djlandreneau
I can't seem to figure out how to change the scale. All references to scale are grayed out and can not be edited.
Mon, Jun 5, 2006 at 3:58:25 AM | RE: Fill Pattern
Will9000
4 Stars: 5 Votes
Click on surface properties icon click on new, custom, import, find your hatch pattern load it in, then click on the imported file name next to "import" (in the white block), you can then change your scale Hope that helps Will
Mon, Jun 5, 2006 at 8:13:21 PM | RE: Fill Pattern
djlandreneau
Thanks all, that did it. Not too intuitive on Revit's part to explain in its help files how to do.
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Scaling fill pattern
Thu, Nov 17, 2011 at 4:01:24 PM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Fill Pattern not show up when print
Wed, Apr 25, 2012 at 4:08:55 AM
Lost Solid Fill Pattern
Wed, Apr 9, 2008 at 7:58:47 AM
Page generation time: 0.6047
