Forums >> Revit Building >> Technical Support >> I'm surprised... thin roofs are transparent?
Thu, Oct 4, 2018 at 4:38:45 PM | I'm surprised... thin roofs are transparent?
Marquand
Hi - I'm using roofs that are just the comp shingle and plywood in thinkness, no structure. In elevations I can't seem to eliminate a double line in the roof ridges, that seems to be like the roof is transparent and you see it like a wire frame. I've tried all sorts of transparency settings but nothing affects it. WHen I change to roof to 4" thick, same problem. When I make it 6" thick, the problem goes away. But I really don't want a 6" thick roof. Any suggestions? I'm working with structural eng who is doing revit and I just the plywood to lay on top of the trusses with no structure in the architectural model.
Thanks!
Thu, Oct 4, 2018 at 8:08:15 PM | I'm surprised... thin roofs are transparent?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Could be your display, graphic card issue perhaps. I cannot replicate you problem on my system (gtx 1070). Turn hardware acceleration off, see what happen.
Upload your file, I can test it if you want.
transparent roof [ 1 2 ]
Fri, Dec 2, 2005 at 1:14:04 PM
20
Transparency problem. Inserting tif's for decals, the transparent background...
Thu, May 24, 2012 at 12:47:44 PM
REVIT 2014 - Still no 'Metal Deck' in Roofs
Thu, Apr 18, 2013 at 1:20:27 PM
Transparent Demolished
Fri, Aug 25, 2006 at 3:45:35 AM
Transparent object
Tue, Sep 14, 2010 at 1:18:34 PM
Page generation time: 5.4927
