Forums >> Revit Building >> Technical Support >> Non-Continuous Top Rail of a Railing Strucutre
Thu, Oct 4, 2018 at 1:59:26 PM | Non-Continuous Top Rail of a Railing Strucutre
sgray05
Does anyone know if I can create a non continuous top rail of a railing assembly? I have a railing design that involes flat bars for top rail that are interupted by the post that extend a couple inches above the bar.
The bar width is greater than the post so ideally I would like to post to be able to break the rail, but I have had no luck in figuring out how to do this, if it can be done.
Thanks
Thu, Oct 4, 2018 at 7:52:37 PM | Non-Continuous Top Rail of a Railing Strucutre
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
Use multiple rails: main rail w/o top rail and fill in-between posts with another rail element consists of handrail/top rail only.
Fri, Oct 5, 2018 at 3:24:00 AM | Non-Continuous Top Rail of a Railing Strucutre
tim123
4 Stars: 19 Votes
You can create a baluster panel that is the correct length for the interupted part and space it to suit the posts.
2015 use baluster per tread on stair (with no top rail?)
Thu, Sep 3, 2015 at 4:50:57 PM
Baluster Top Offset Issue
Tue, Jan 12, 2016 at 8:43:40 AM
Railing not shown in list
Mon, Jun 30, 2014 at 4:25:56 PM
How do I change the top rail profile in Revit 2015?
Thu, Sep 28, 2017 at 7:54:29 AM
Editing Top Rail Path on Landings
Thu, Apr 4, 2019 at 4:03:56 AM
Page generation time: 0.2534
