Forums >> Revit Building >> Technical Support >> Align textures at corners in 3D views
Thu, Sep 27, 2018 at 12:36:23 PM | Align textures at corners in 3D views
elizabethpetermathew
Hello, I would like to have textures / patterns aligned as they turn corners in 3D views, not sure how to do it. In exterior elevations they can be aligned. See attached. It lookd wrong in the view. Thank you in advance.
Thu, Sep 27, 2018 at 1:40:37 PM | Align textures at corners in 3D views
You can add temporary reference planes in a view and use those in your other views to align with.
Thu, Sep 27, 2018 at 2:17:03 PM | Align textures at corners in 3D views
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
...or, if this is a model pattern, use align tool in 3D view. You might need to use tab key to get to the desired pattern line.
Fri, Sep 28, 2018 at 1:18:20 PM | Align textures at corners in 3D views
Awesome it worked, thank you!
Rotate 'n' Align Paintbucket Textures
Sun, Nov 18, 2012 at 6:39:30 AM
free hi res textures
Mon, Apr 13, 2009 at 2:47:29 AM
Revit render textures - any good resources on the web?
Thu, Dec 16, 2010 at 10:54:15 AM
Rendering Textures on curved extrusions
Fri, Aug 7, 2009 at 2:21:47 PM
adding textures to wall
Tue, Oct 17, 2006 at 9:27:46 PM
Page generation time: 1.3969
