24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> find elements associated with level (2017)
i would like to delete a level but first i need to find out if there are any and all elements that are using the level for reference or are associated with said level so i dont lose a lot of work?
Correct. Here is Autodesk's solution for this>
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-Model/files/GUID-118C3D05-EE56-45DA-9A1D-00C5BB4DEC86-htm.html
There are are addins that can move objects to a new level and then delete that level such as ARUtils ( see https://www.arsoftwaresolutions.com.au/)Alternatively you need to go through each object in your model and change every one to the new level. On a test copy model, you could create a 3D view, select all objects, count how many objects there are, then delete the level and do a recount to see how many objects get deleted. You should be aware also that plan views are level dependent, so if you delete a level and plans exist that are set to that deleted level, they will also get deleted.
How to find elements on a certain level? |
Mon, Dec 21, 2015 at 6:54:57 AM
Find Objects Associated to a Level |
Fri, Oct 9, 2009 at 1:32:02 PM
select elements on current level only - revit 2014 |
Tue, Jul 23, 2013 at 7:52:33 AM
Find connected objects to a Level? |
Sun, Jan 20, 2013 at 10:45:34 AM
Revit 2017 Text Displaying Differently - Windows 7 & 10 |
Wed, May 17, 2017 at 8:22:58 AM
