13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> BIM 360 Link Issues
I am working off of my Revit model on Bim 360. Everything was set up just fine, and then I had trouble trying to "aquire coordianates". I thought the solution would be to remove the link and try to re link it. However now i can no longer link their BIM 360 model via external referance. (i am not the project manager) I go to "Insert", "Revit Link", "External Resource", "BIM 360", then i select the desired link. My screen flashes as if it will work, but the model never links. (I check manage links and it never appears)
Does anyone have any ideas? I have thought about telling them to delete my model off of their BIM and trying again, but i feel like there has to be a simpiler solution. I do appreciate your time.
Thanks,
It appears that the issue was coming from within the file i was trying to link into my model. The Mechanical & Electrical models that were linked into the Architectural were not allowing me to link the Architectural into my model. Once these were removed from that Architectural model I was able to re-esablish the link just fine.
Can't Remove File from BIM 360 |
Wed, Apr 10, 2019 at 8:59:16 AM
BIM 360 & REVIT IPD |
Fri, Feb 17, 2017 at 1:29:08 PM
Sharing Revit Models and content - BIM 360, etc |
Fri, Jan 11, 2019 at 4:17:08 PM
What happened to C4R Communicator? |
Fri, Aug 16, 2019 at 10:12:09 AM
Revit link dwg issues |
Mon, Jul 1, 2013 at 8:09:19 AM
