15 Users Online (13 Members):
Forums >> Revit Structure >> Technical Support >> Phase Graphic Overides
Revit 2018.2
Hopefully a straightforward query - We use phasing regularly and it is a great tool. I have picked up a colleagues drawing and the Phasing Graphic Overides are not overiding the fill patterns. The elements are instead taking direction from their Coarse Scale Fill. Can someone advise how to change this? It's a problem I've never come across before, phasing usually works perfectly. Note - this is the case in all view, with different phase filters
Is there a view template set for all the views? Check the visibility graphics for overrides.
Can graphic overides allow "translucent hatching" |
Fri, Jun 29, 2007 at 2:32:58 PM
Dual Phase Graphic Override? |
Tue, Apr 28, 2009 at 9:23:26 AM
New Phase Wall Fills - arghhh! |
Fri, Mar 2, 2007 at 1:33:03 PM
create a filter for floor surface patterns below |
Mon, Dec 3, 2018 at 12:04:35 AM
Visibility overides in a linked revit model |
Tue, Jul 8, 2008 at 4:12:34 PM
