9 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Section on sheet
Greetings
I made, and edit the crop... it seems good,
But when I drag it to sheet it disappeared...
And when reset the crop it appears again...
Is there way to make appear with out resting
The crop..?!
What disappears, the section?
Yes most of it, except a few lines,
Happen when I drag it on sheet...
The problem could be your video card.
Did you know that you can edit a view while it is on a sheet? Try that.
Will check the video card...
Thanks for you
Section line disappears from plan when section view is placed on same sheet |
Thu, Sep 4, 2014 at 7:46:20 AM
Changing Sheet References |
Thu, Sep 18, 2008 at 9:57:06 PM
original title section changes when duplicated view is created on a new sheet - |
Fri, Mar 13, 2015 at 10:17:47 AM
NEWBIE HERE - How to change section head type |
Mon, Aug 1, 2011 at 7:46:01 AM
section marks |
Tue, May 17, 2005 at 12:54:13 AM
