Forums >> Revit Structure >> Technical Support >> Zero thickness Plane
Fri, Aug 31, 2018 at 4:51:39 PM | Zero thickness Plane
gregroberson
gregroberson Avatar
Is it at allk possible to extrude or sweep a 2D element, like a line.  I am trying to make a family or model comprized of zero thickness planes that appear as 2D lines when cut in a perpendicular view.
I cant seem to find any answers and have tries everything that makes sense to me?  ANy thoughts would be greatly appreciated .... I would love to show this functionality to everyone blocking revit usage at my office.
Greg
Fri, Aug 31, 2018 at 10:33:18 PM | Zero thickness Plane
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
A typical extrusion requires a closed loop. That means thickness. But, you can use massing environment to create a form (extrusion) out of a line.
Toposurface thickness?
Tue, Jan 24, 2012 at 9:55:03 AM
Wall Thickness in Type Parameter
Fri, Jun 1, 2018 at 7:39:15 AM
Wall Thickness variable
Tue, Apr 12, 2005 at 11:37:44 AM
Variable Thickness Wall?
Fri, Feb 10, 2017 at 6:09:58 PM
Changing wall thickness issue
Thu, Oct 12, 2006 at 11:07:14 AM
Page generation time: 3.5494
