Forums >> Community >> Newbies >> Conduit Fitting Dimension
Thu, Aug 16, 2018 at 11:35:17 AM | Conduit Fitting Dimension
swooll3
1 Stars: 1 Votes
Hello,
What would be the best way to pull a dimension from the center of a conduit fitting. I have some 90 degree bends that need dimensions right on the center of the 90. I tried adding some detail lines in the family but still can't see them placed in the model correctly.
Thu, Aug 16, 2018 at 1:05:40 PM | Conduit Fitting Dimension
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
In family editor, use reference lines instead of detail lines. Select each one and in properties change them to Strong reference. Save and import into model. You should then be able to put dimension to the reference lines even though you cannot see them.
Thu, Aug 16, 2018 at 4:24:30 PM | Conduit Fitting Dimension
swooll3
1 Stars: 1 Votes
Worked perfect. Thanks
Cable Tray- Revit MEP 2013
Thu, Oct 4, 2012 at 6:22:42 PM
Conduit
Tue, Jan 22, 2019 at 2:22:21 AM
Defining conductor types in Conduit
Fri, Jan 4, 2013 at 5:12:25 PM
DIMENSIONS HELP!
Wed, Jul 26, 2017 at 2:25:05 PM
Conduit problem
Wed, Sep 15, 2010 at 10:12:12 AM
Page generation time: 0.2756
