Forums >> Revit Building >> Technical Support >> create a family parameter to orient object to show either landscape or portrait
Tue, Aug 14, 2018 at 2:14:02 PM | create a family parameter to orient object to show either landscape or portrait
brookecanderson
I'm creating a family that is a wall hosted markerboard.  It needs to have a parameter that you can check so the orientation of the board is either landscape or vertical.  Any ideas on how to do this?
Tue, Aug 14, 2018 at 3:48:25 PM | create a family parameter to orient object to show either landscape or portrait
Why didn't you build the board with two type parameters - length and width?
Tue, Aug 14, 2018 at 8:14:52 PM | create a family parameter to orient object to show either landscape or portrait
brookecanderson
It does have the height and width parameters, but the client wants to be able to select either landscape or portrait
Wed, Aug 15, 2018 at 12:26:52 AM | create a family parameter to orient object to show either landscape or portrait
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just make two different sets of solid geometry and then use a Yes / No parameter to turn them off or on depending on the chossen geometry.
https://www.youtube.com/watch?v=rzsnkETnUsgv
https://www.youtube.com/watch?v=hGmAtQjqhFc
Printing Question
Wed, Nov 16, 2011 at 10:35:56 PM
Create Roof Family Object
Mon, Nov 21, 2005 at 7:10:42 PM
Nested annotation labelt o report a family parameter?
Tue, Oct 15, 2013 at 4:05:27 PM
Orient section cut to object
Sun, Jan 31, 2010 at 8:28:59 AM
CIP Landscape Stairs
Thu, Apr 7, 2005 at 12:35:34 PM
Page generation time: 1.5344
