18 Users Online (17 Members):
Forums >> Revit Structure >> Technical Support >> Bottom of Pipe Elevation
0 Posts No Rating |
Revit 2017 - I have a site plan and I want to do a spot elevation to the bottom of the pipe. It keeps snapping to the top of pipe. Is there a way to snap to the bottom of the pipe or am I missing siomething. I have attached a PDF of what I am talking about. The b.o.p should read 12'-9 3/4" which it is at 12'-9 3/4"
0 Posts No Rating |
I got it - Thanks Byron
This site works because of good questions and answers. If you answered your own question, we ask you to post the answer for others to see.
0 Posts No Rating |
It was really simple when I calmed down and looked slowly.
0 Posts No Rating |
Place Spot elevation, Select the tag and look in properties under text you havfe a slection for top, bottom elevations
pipe dimensions |
Wed, Dec 2, 2015 at 7:47:03 AM
Spot elevation Tag and Insulation |
Wed, Jun 11, 2014 at 10:00:27 AM
Centerline elevation of pipe below underside of floor above |
Mon, Dec 22, 2014 at 8:11:21 AM
Issues with Pipe elevation tagging |
Mon, Aug 24, 2015 at 8:23:31 AM
Invert Elevation Vs. Spot Elevation |
Mon, Apr 20, 2015 at 2:09:11 PM
