Forums >> Revit Building >> Technical Support >> Change Elevations in to the project.
Wed, Aug 8, 2018 at 2:11:31 PM | Change Elevations in to the project.
1bchristian
Is it possible to change the level elevations without moving the model up or down?
Wed, Aug 8, 2018 at 3:42:58 PM | Change Elevations in to the project.
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can change your survey or base point elevations and have your elevation markers read one or the other.
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/Revit-Collaborate/files/GUID-68611F67-ED48-4659-9C3B-59C5024CE5F2-htm.html
Thu, Aug 9, 2018 at 10:30:40 AM | Change Elevations in to the project.
1bchristian
THANKS - IT WORKED
Topo surface points change from relative to absolute elevations [ 1 2 ]
Thu, Apr 7, 2016 at 9:33:19 AM
15
Default Elevations missing in project
Fri, Apr 5, 2013 at 7:21:37 AM
Level elevations
Thu, Sep 11, 2014 at 12:54:39 PM
Loading Families into a project after a change - Always necessary?
Fri, May 25, 2012 at 12:06:18 PM
changing base project elevations
Mon, Jun 22, 2009 at 4:15:15 AM
Page generation time: 2.6607
