Forums >> Revit Building >> Technical Support >> Lost as a goon.
Mon, Aug 6, 2018 at 2:24:09 PM | Lost as a goon.
1bchristian
Revit 2017 - I am drawing 3d PVC conduit like the attached shows. I now want to put vertical conduit in but don't seem to be able to get into the right work plane so that I can draw vertical condiuts. Maybe I donlt understand work planes if they con;t work like autocad. Any help would be appreciated - Thanks Byron
Mon, Aug 6, 2018 at 4:32:04 PM | Lost as a goon.
The image tells us nothing.
Do you understand how to create work planes and set them to be active?
Mon, Aug 6, 2018 at 4:58:38 PM | Lost as a goon.
1bchristian
No I donot understand work plans - Thanks byron
Mon, Aug 6, 2018 at 6:30:38 PM | Lost as a goon.
Reference / work planes work the same in both families and models.  In a model you start out with built in work planes - the floor levels.  Those are horizontal.  You can add column lines which can also be set as work planes and they are vertical.  Then you have other reference planes that you can create and name that are at any angle.
In a test project, add some column lines.  Go to an elevation view that is parallel to those lines.  Now you can set your work plane to be one of those column lines (planes) and you can add elements that in 3D are on that grid.  You can do the same with reference planes you create.... just always name them.
In your case, adding a vertical line pipe to a horizontal one, you could draw a reference plane in plan in the center of the pipe then go to an elevation view that includes that plane, select it and draw your pipe.   <<<  This is a very simple example but it will start you down the right road.
DO THE ABOVE AND LOOK AT IT IN 3D.
Tue, Aug 7, 2018 at 11:46:59 AM | Lost as a goon.
1bchristian
i MUST NOT UNDERSTAND HOW TO CREATE A WORK PLANE. - THANKS BYRON
Wed, Aug 8, 2018 at 12:57:13 AM | Lost as a goon.
tim123
4 Stars: 19 Votes
Create a reference plane.  You need to give it a name so that you can choose it.
Wed, Aug 8, 2018 at 10:18:32 AM | Lost as a goon.
1bchristian
I think I got it  - Thanks Byron
LOst Title shhet
Fri, Nov 13, 2015 at 4:08:01 PM
recovering lost files
Tue, Sep 2, 2014 at 1:28:11 PM
New from Portland, lost my 3d model
Tue, Mar 13, 2012 at 9:34:29 PM
lost .rft files
Mon, Jun 28, 2010 at 7:02:40 PM
lost function to middle button on mouse
Mon, Apr 28, 2008 at 7:36:35 PM
Page generation time: 0.0593
