Forums >> Revit Building >> Technical Support >> Eave Return
Fri, Jun 2, 2006 at 4:03:19 PM | Eave Return
djlandreneau
Hi All, A very popular design style here in Atlanta is a return on the eave. Does anyone know how to make this in Revit? DJ
Fri, Jun 2, 2006 at 5:26:55 PM | RE: Eave Return
latemore
latemore Avatar
3 Stars: 2 Votes
maybe send us all an image of what you are trying? down here in aussie land, we may not have that detail! otherwise, why not do two rooves, and join rooves?
Sat, Jun 3, 2006 at 8:03:09 AM | RE: Eave Return
coreed
coreed Avatar
4 Stars: 16 Votes
"For the most comprehensive roof explanations I've seen, log into the subscription center, go to the AU2005 website and download the class handout from BD31-1 "Moving On Up and Keeping Dry with Autodesk Revit - Stairs and Roofs" by Jim Balding and Scott Brown of WATG." Quote from Tom Dinmn HTH
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Jun 3, 2006 at 8:29:29 AM | RE: Eave Return
djlandreneau
Which subscription center are you referring to?
Sat, Jun 3, 2006 at 9:03:06 AM | RE: Eave Return
coreed
coreed Avatar
4 Stars: 16 Votes
here is the link http://pointa.autodesk.com/local/enu/portal/signin.jsp if you purchased Revit with a subscription you get access to all of the material from Autodesk University annual meeting through this site HTH Post edited on 2006-06-03 22:42:30
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Sat, Jun 3, 2006 at 10:24:13 AM | RE: Eave Return
gerryh06
3 Stars: 1 Votes
if we do not have a subscription, how much does it cost to get one? Is there a discount on price for students?
Sat, Jun 3, 2006 at 4:19:14 PM | RE: Eave Return
Dgodfrey
4 Stars: 4 Votes
If the attached is what you are referring to, it's done with 2 joined roofs. The second attachment shows the smaller cornice return roof in edit mode with the corner hipped as is the larger main roof it is attached to. This isn't necessary when you join the roofs as they will clean up as long as they are EXACTLY aligned. By drawing the roofs as a hip at the corner allows the fascias to clean up automatically vs. adjusting with grips. whatever you find easier. attachments aren't working. i can e-mail if you're still interested Post edited on 2006-06-03 16:20:53
Sat, Jun 3, 2006 at 4:29:59 PM | RE: Eave Return
Dgodfrey
4 Stars: 4 Votes
I think the bitmaps were too big. I hope these work.
Sat, Jun 3, 2006 at 4:32:49 PM | RE: Eave Return
Dgodfrey
4 Stars: 4 Votes
second file i give up Post edited on 2006-06-03 16:33:17
Fri, Jan 19, 2007 at 2:37:56 PM | Eave Return
impala94
I can not find the referenced information on the AUGI site.  and I am trying to get my roof eaves to look like the following.  Any suggestions, right now i have the second sketch from what i can figure out.
Fri, Jan 19, 2007 at 2:40:08 PM | Eave Return
#11
impala94
photo didnt attach...trying this...
Fri, Jan 19, 2007 at 4:55:02 PM | Eave Return
#12
framerman
4 Stars: 13 Votes
I'm not sure what you're looking for. Is it a gable trim board?
Edited on: Fri, Jan 19, 2007 at 4:55:43 PM
Sat, Jan 20, 2007 at 2:04:27 PM | Eave Return
#13
Westview
2.5 Stars: 2 Votes
I am ot sure what you are refering to. If it is the fascia trim on the outside of the gable overhang than I would create a solid extrusion in the elevation view and lock it at 19mm or 25mm thick than in the plan view move and lock it to the gable overhang.
Mon, Jan 22, 2007 at 12:18:31 PM | Eave Return
#14
impala94
I am looking for both the solid eave return and the gable end trim board.  As you can see from my sketch (maybe) i can get an eave return but it leaves a triangular void above it that shows in the elevational views.  Do i have to do it like i would in autocad and draw the triangular profile and extrude it around the roof profile?
sorry for the newb questions but i am...heh
Thu, Jan 25, 2007 at 3:43:48 PM | Eave Return
#15
impala94
ok, long story short, I did the attached house in Autocad, we are trying to put it into revit to use it for modelling and other marketing purposes.  With that being said, we used extended bottomo chord trusses to get flat eave returns.  Revit is only using extended top chord trusses (sorta) to frame the roof so I need to get the gable ends to have the profile in the attached photo.  Any suggestions, please be explicited as i have about 2 weeks of self taught training.
Thanks
John
Varying eave heights on roof [ 1 2 ]
Wed, Aug 11, 2010 at 8:21:37 PM
23
butterfly roof, curved in plan and at eave
Sat, Feb 12, 2011 at 8:07:03 AM
Boxed in Eave Roof
Thu, Jun 14, 2012 at 11:14:54 AM
roofs with different eave height
Thu, Oct 6, 2011 at 3:02:44 PM
Eave Strut Problem!
Tue, Mar 20, 2007 at 12:04:13 PM
Page generation time: 0.0284
