Forums >> Revit Systems >> Technical Support >> Link CAD
Thu, Jul 26, 2018 at 2:16:48 PM | Link CAD
MrFernandez
Im having trouble loading a Link CAD file to Revit. Anybody have suggestions to have this done?
Thu, Jul 26, 2018 at 4:51:14 PM | Link CAD
Follow the instructions in your HELP....it works.
Fri, Jul 27, 2018 at 9:28:46 AM | Link CAD
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Assuming by CAD this is an AutoCAD DWG file. Open it first in CAD and delete anything you dont want including all sheet views. Use lisp app "Iron" in AutoCAD to flatten everything in drawing to 0 (z plane). audit, purge and overkill everything. Set to correct scale to match Revit ( eg Metric use millimetres.) Move all drawing content in AutoCAD to 0,0,0. Save and close.In Revit go to floor plan that the AutoCAD file applies and open it, insert tab, Link section,  link CAD, navigate to autocad file, set import units to millimetres, positioning to manual centre and click open. You should see it.
Link CAD, Import CAD in the middle of space
Tue, Sep 21, 2010 at 3:43:46 PM
CAD inserts appear in as many copies in my manage link view
Fri, May 15, 2020 at 5:17:44 PM
Insert/Link CAD Advice
Wed, Dec 21, 2011 at 2:56:22 PM
Text formating in CAD link
Fri, Mar 15, 2013 at 9:52:22 AM
CAD Link nor CAD Import visible
Fri, Apr 1, 2011 at 8:34:09 AM
Page generation time: 1.0112
