Forums >> Revit Building >> Technical Support >> Ceilings in Revit
Fri, Jun 2, 2006 at 2:27:17 PM | Ceilings in Revit
smartinez
I am trying to create a Ceiling family similar to the System family for a 2 x 2 drop ceiling - the difference being in the actual system layout. The current System Family offers ceilings that have the ceiling tile under the structure. In reality most drop-ceilings have the panel lay inside of the structural tees. Any one have any suggestions?
Thu, Nov 15, 2012 at 4:02:52 PM | Ceilings in Revit
mand0003
does anyone know how to start a new thread on here?  I picked start new thread but it brings me to some other webpage, all i can do is reply to other threads.
I'm having an issue with automatic ceilings in Revit 2012.  for some reason it doesn't always work.  I have made sure all my elements are room bounding, but I can go along placing ceilings and when I hover over the room, it highlights the room enclosure, then when I pick, the outline turns pink but no celing is placed.  If I pick another room, I get an error, if I hit enter, it just goes away.
I called my reseller they say it is a known glitch with no hot fix.  They say it occurs in 2013 as well.   I find this hard to believe as it is a big PIA.  I have a 10 story building with about 40 rooms each, only about 30% of the room will allow automatic ceiling which means I have to manually sketch almost all of them.
Incidently, I can place rooms in these spaces with no problems.  Anyone see this issue or have suggestions?
Thanks,
Thu, Nov 15, 2012 at 4:10:07 PM | Ceilings in Revit
I don't know what you are picking.  From the forums page, click on the forum you think you should post in and click on "Start New Thread".
We have no problems so I know there is no glitch ... unless it was in an earlier build.  Make sure you are up to date I think update 1
Complex ceilings
Thu, Oct 8, 2015 at 1:02:54 PM
Vector Printing - Ceilings Disappear
Wed, May 28, 2014 at 9:12:41 AM
Ceiling diffusers not showing up in ceilings when combined with architecturals
Wed, Sep 2, 2009 at 5:20:10 PM
Sloped Ceilings
Thu, Jan 23, 2014 at 4:54:40 PM
14
Model In Place Ceilings Not Scheduling??
Wed, Jan 15, 2014 at 10:55:35 AM
Page generation time: 2.0819
