20 Users Online (18 Members):
Forums >> Community >> The Studio >> spoiled ctrl TAB no longer works
Hi, I have noticed that the control-tab, in Revit 2019, no longer returns you to the LAST window you were. It loses the secuence at all. Or am I missing something, any tip about it?
I beleive this is a new feature in Revit 2019. If you have multiple views open, the tabs are positioned just below your ribbon. Control+Tab cycles to the right, Shift+Control+Tab cycles to the left.
Yeah, it seems so. Make no sense to have the tabs order in one hand and "ctrl-tab" doing the same in the other, instead of taking you cycling back your way. It is stupid.Edited on: Fri, Jul 27, 2018 at 10:09:41 AM
Edited on: Fri, Jul 27, 2018 at 2:57:17 PM
Can I change the 'ctrl + Tab' shortcut to switch between windows to a (2) digit? |
Thu, Jun 26, 2014 at 2:51:35 PM
View Previous |
Fri, Nov 13, 2009 at 12:21:46 PM
Revit crashes whenever I hit CTRL + Tilde key |
Tue, Dec 7, 2010 at 7:19:36 PM
using contol or option keys when setting hot keys? |
Mon, May 18, 2009 at 4:47:26 AM
PASTING IN THE SAME PLACE w/Ctrl+C_Ctrl+V |
Mon, Mar 28, 2016 at 11:32:04 AM
11
