Forums >> Revit Structure >> Technical Support >> Create a moulding I think.
Tue, Jul 24, 2018 at 10:06:36 AM | Create a moulding I think.
1bchristian
Revit 2017 - Does anyone know and can tell me how to approch create something like the attached in revit. - Thanks Byron
Tue, Jul 24, 2018 at 10:12:32 AM | Create a moulding I think.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
What are you using it for first?
Tue, Jul 24, 2018 at 10:22:02 AM | Create a moulding I think.
1bchristian
Revit 2017 - I am using it on the attached furniture. - Thanks Byron
Tue, Jul 24, 2018 at 10:37:15 AM | Create a moulding I think.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Got to front elevation, create tab, Forms section, Extrusion, Trace perimeter & holes of shape, click green tick icon in ribbon to finish, go to plan and click the extrusion you created and adjust its length to suit whatever width it is. Repeat the above for the inner webs. In plan select both shapes, rotate and move to correct orientation. Copy as required.
Tue, Jul 24, 2018 at 10:56:26 AM | Create a moulding I think.
1bchristian
Beatiful worked like a champ - Thanks for the instructions. Byron
Tue, Jul 24, 2018 at 11:20:05 AM | Create a moulding I think.
1bchristian
Revit 2017 - I hit another stump, How to rotate something about the x axis to have it stand up. I have attached the file agian and you can see that the cross is laying down. I need to stand it up and attach to the center door.
Wed, Jul 25, 2018 at 10:32:26 AM | Create a moulding I think.
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
You have to go to the elevation view that is correct for the rotation orientation. It won't let you do it in a 3D view. Sometimes in models objects still won't rotate as they are associated with a certain plane. To disassociate that relationship, you copy the object and paste it and then rotate the duplicate object.
Adding quarter round moulding to existing base board moulding
Tue, Nov 20, 2007 at 8:43:48 PM
Curtain wall not cutting through moulding
Thu, Oct 22, 2015 at 2:53:44 PM
baseboard moulding
Fri, Jan 27, 2017 at 10:40:33 AM
Help with a single stone moulding window
Thu, Aug 18, 2005 at 3:31:42 AM
Crown Moulding Return
Thu, Aug 22, 2013 at 2:52:28 PM
Page generation time: 3.7212
