Forums >> Revit Building >> Technical Support >> Dummy Callout for 2017
Tue, Jul 24, 2018 at 12:35:02 AM | Dummy Callout for 2017
gkp7929
2.5 Stars: 2 Votes
Hi guys, i need a help..
Need dummy callout...with option for adding sheet name and view number.
Please help asap..
Thanks
GB
Tue, Jul 24, 2018 at 12:57:21 AM | Dummy Callout for 2017
tim123
4 Stars: 19 Votes
Try the "Reference Other View" and then refer it to the view that you would like.
Tue, Jul 24, 2018 at 1:40:12 AM | Dummy Callout for 2017
gkp7929
2.5 Stars: 2 Votes
I dont want to give reffrence other view option ..as my detail sheets are preparing in cad...just need a dummy callout to show
Tue, Jul 24, 2018 at 2:19:16 AM | Dummy Callout for 2017
gkp7929
2.5 Stars: 2 Votes
found a file in 2019..but i dont have 2019 version..can anyone make same thing in 2017 and send it to me..i got a submission today..it will be a big help if anyone can do it for me.. TIA
Tue, Jul 24, 2018 at 4:13:34 AM | Dummy Callout for 2017
tim123
4 Stars: 19 Votes
Create dummy views with the same name as the CAD views.  But it's simple enough to create what you want from scratch using a generic annotation family - why don't you try that?
Tue, Jul 24, 2018 at 10:42:39 AM | Dummy Callout for 2017
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
When we need our sections/plans/ etc to reference to a detail drawing in AutoCAD, we place a normal detail into the correct section/plan/ etc and place that callout detail onto a sheet with the correct sheet name. We then write across it in big bold letters to refer to AutoCAD sheets. This way callout references correctly. Staff can visibly track the path where the detail is and the sheets can be scheduled.
You could also just do it with dumb 2D lines and dumb text.
Thu, Oct 4, 2018 at 8:48:19 AM | Dummy Callout for 2017
Natasha00123
I need a dummy callout as well... you can't make a floor plan view or even a floor plan view reference in a detail view. Too far along to remake the detail views into a floor plan view and Revit will not let you change it. Need a dummy tag as a work around. Wish Revit would let us open families in previous versions!!! Sad
Dummy Callout Heads
Tue, Jan 28, 2014 at 3:35:50 PM
Dummy Callouts, are they possible?
Thu, Oct 29, 2015 at 5:35:30 AM
Masking Text in callout
Tue, May 10, 2011 at 5:43:29 PM
Callout tags
Thu, May 1, 2008 at 11:39:20 PM
12
Revit 2017 Text Displaying Differently - Windows 7 & 10
Wed, May 17, 2017 at 8:22:58 AM
Page generation time: 1.0800
