Forums >> Revit Structure >> Technical Support >> swing lines on casework doors
Fri, Jul 20, 2018 at 10:25:42 AM | swing lines on casework doors
1bchristian
Revit 2017 - I have attached my problem. I place swing lines on my doors but they do not show in elevation. What am I doing wrong in the attached. I have also having the same problems with hardware. - Thank you - Byron
Fri, Jul 20, 2018 at 10:53:48 AM | swing lines on casework doors
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Your swing lines are 'model lines' not 'detail lines' and they are right on the surface of the cabinat panel. That's the problem. Swing lines are usually Detail lines and the visibility only shows when viewed in elevation. If you want to use model lines to be seen in 3D etc create a workplane slightly off the surface of the cabinet panel and put them on there.
If you view your cabinet, as is, in the project in 'Wireframe' in any view the swing lines will show up.
Edited on: Fri, Jul 20, 2018 at 10:55:45 AM
Opposing swing on doors
Fri, Aug 24, 2007 at 12:16:06 PM
How to make doors flippable in family?
Wed, May 30, 2007 at 8:23:48 PM
Is it possible to separate metal and glass doors swing color in floor plan?
Mon, Sep 25, 2017 at 5:34:13 AM
Doors-Swing projection doesnt match Panel in Floor plan
Wed, Dec 14, 2011 at 10:03:05 AM
REVIT 2014: Door Elevations - swing lines are shown backwards? [ 1 2 ]
Tue, May 12, 2020 at 2:41:52 PM
16
Page generation time: 0.6569
