Forums >> Revit Building >> Technical Support >> VOIDING TOPO FOR FNDN HOLE??
Fri, Jun 2, 2006 at 11:45:07 AM | VOIDING TOPO FOR FNDN HOLE??
ICON
5 Stars: 3 Votes
After creating topo surface, I need to punch a hole for my foundation to look correct in some perspective shots. Is this what "pad" is for or is there another prescribed method??
Fri, Jun 2, 2006 at 12:10:16 PM | RE: VOIDING TOPO FOR FNDN HOLE??
gerryh06
3 Stars: 1 Votes
You can create the topo surface. Click on split surface, draw the outline of what you want to cut out. And then ok it. And then add another surface or create your foundation from there. hope that helps Gerry
Fri, Jun 2, 2006 at 12:37:31 PM | RE: VOIDING TOPO FOR FNDN HOLE??
bolandereric
The Pad Command works really well.
Fri, Jun 2, 2006 at 12:38:07 PM | RE: VOIDING TOPO FOR FNDN HOLE??
macest
Yes, the pad will outline the building for you and then you can just turn if off the perspective, so all you'll see is the dirt. Also, you can use the Graded Region from the Site tools. The original topo needs to be in the previous phase and it demos that surface and creates a duplicate in your current phase. When selecting the surface, be sure the "copy internal points" check box is marked and then you can alter the topo points at the foundation area. These are very rough since I'm still working on them, but here are 2 jpgs - one showing site work and then next showing digging out the side of the hill to start foundations. Hope this helps.
Fri, Jun 2, 2006 at 2:13:03 PM | RE: VOIDING TOPO FOR FNDN HOLE??
ICON
5 Stars: 3 Votes
THANK YOU.
Mon, Jun 5, 2006 at 4:09:42 AM | RE: VOIDING TOPO FOR FNDN HOLE??
Will9000
4 Stars: 5 Votes
Hi Macest I notice on your attachment you have a JCB, can you let me know where you found this, (as i need one well a trctor is what i am after) but hopefully i will be able to modify the family, many thanks Will
Mon, Jun 5, 2006 at 1:04:26 PM | RE: VOIDING TOPO FOR FNDN HOLE??
macest
Will 9000 - I actually exported the items from ArchiCAD as dwgs, then made them Revit families. The only problem is that the coloring doesn't import correctly, and when rendered, they reder in solid grey. I'm working on that now. Actually, all the objects on that drawing were from ArchiCAD. By JCB are you referring to the Pile Driver or the backhoe? I have a slew of other objects as well, that I got by the same method. I may have a tractor I can upload if it will save you some time. What sort of tractor?
Mon, Jun 5, 2006 at 2:00:38 PM | RE: VOIDING TOPO FOR FNDN HOLE??
coreed
coreed Avatar
4 Stars: 16 Votes
hi macest, did you switch from Archicad to Revit or are you using both programs? just curious
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Mon, Jun 5, 2006 at 2:23:36 PM | RE: VOIDING TOPO FOR FNDN HOLE??
macest
I've been a Revit user since v. 1.0, so my models are done completely in Revit. ArchiCAD does still have a better library of elements, so I use that only to export what I'm missing.
Wed, Jun 7, 2006 at 3:26:48 AM | RE: VOIDING TOPO FOR FNDN HOLE??
Will9000
4 Stars: 5 Votes
Hi Macest, What i am after is basically a bog standard tractor, i need to use it as i am doing some development on a farm, I have never used Archicad and came to revit straight from AutoCad, but if yuo can upload a family for a tractor it would be very much appreciated Will
How to infill a topo hole from plit surface
Fri, Jun 15, 2012 at 9:54:54 AM
Hole in my topo surface
Thu, Nov 8, 2012 at 8:36:26 AM
11
Deleted Topo Surface
Fri, Apr 2, 2010 at 3:54:58 PM
Applying Materials To Cover A Hole
Mon, Mar 10, 2008 at 8:26:30 PM
hole in the second level for stairs?
Fri, Apr 24, 2009 at 9:42:58 PM
Page generation time: 2.1044
