Forums >> Revit Systems >> Technical Support >> Piping families...
Fri, Jul 13, 2018 at 8:48:03 PM | Piping families...
MSRoble33
4 Stars: 1 Votes
Is it me or is Revit completely void of any good piping components?
I see no long-radius carbon steel, or stainless steel.. which is industry default. And the elbows they do have have shorter bend radiuses than the short radius elbows REALLY have.
No ductile iron...
Even the pipe ODs of the stuff they DO have is wrong.
Anyone know where I can download proper families for this stuff?
Fri, Jul 13, 2018 at 8:50:57 PM | Piping families...
MSRoble33
4 Stars: 1 Votes
I stand corrected about the OD's, I found the type that was correct... :-D
Fri, Jul 13, 2018 at 8:59:48 PM | Piping families...
MSRoble33
4 Stars: 1 Votes
I caved, I opened up the existing fittings, reverse engineered the family, and modified it to work.
However, I'm going to need to verify a bunch of fittings.
Mon, Oct 22, 2018 at 3:38:49 AM | Piping families...
kavianitina
anyoe can help me with pipe supports? I need some floor pipe support
Mon, Oct 22, 2018 at 9:20:59 AM | Piping families...
MSRoble33
4 Stars: 1 Votes
I've found that Fabrication for Revit is the way to go. But you need CADMEP to modify the services.
They have supports in there. By default, they have hangers, I have not dug into expanding upon that yet, but that's on my to-do list.
You CAN download things straight from the manufacturers too. But most supports that are posted up, are generally designed and built, and not purchased, so I'm thinking for those, you may be able to make families for those that you can connect, and stretch as you need.
Piping loops
Wed, Apr 30, 2008 at 12:35:59 PM
Connecting Sanitary Piping
Thu, Dec 13, 2012 at 3:42:23 AM
Is it possible to copy from job to job a piping layout like back to back toilets
Fri, Sep 25, 2009 at 3:54:07 AM
Piping System Families
Mon, Dec 3, 2012 at 3:46:31 PM
Adding materials to piping systems
Mon, Oct 12, 2009 at 4:07:42 PM
Page generation time: 0.2151
