Forums >> Revit Building >> Technical Support >> Adjust Brick veener to move down agianst the brick ledge.
Fri, Jul 13, 2018 at 2:08:27 PM | Adjust Brick veener to move down agianst the brick ledge.
1bchristian
Revit 2017 - I have a problem when I stretch the brick veener to meet the brick ledge and then go back to plan the exterior walls do not fillet
properly anymore - is this correct or am I doing something wrong? I have attached a image - Thank you Byron
Sat, Jul 14, 2018 at 6:36:47 AM | Adjust Brick veener to move down agianst the brick ledge.
Revit will always do this when you adjust a layer on one side of an intersection.  It doesn't know what to do when the two sides are not the same.
Tue, Jul 17, 2018 at 3:11:33 PM | Adjust Brick veener to move down agianst the brick ledge.
Rescue5Heroes
Have you also tried to adjust the join order of the two walls? So that your left wall is extended to the edge of your top wall.
Thu, Jul 26, 2018 at 1:23:53 PM | Adjust Brick veener to move down agianst the brick ledge.
Uncreatedbody
How is your brick veener being used in your model? Part of the wall make-up/construction or as a wall sweep? Check if the brick veneer is selected to wrap when you edit the structure.
These walls that intersect are the same construction, correct?
Thu, Jul 26, 2018 at 2:23:13 PM | Adjust Brick veener to move down agianst the brick ledge.
1bchristian
Yes both walls or all exteriro walls are identical. This was correct then it happened when I stretched my brick down to the brick ledge. the brick is in the wall mek up.
Brick Ledge?
Wed, May 18, 2011 at 10:11:35 AM
Brick Ledge Question in RAC 2011
Tue, Feb 8, 2011 at 11:34:45 AM
Why won't my brick ledge show in plan
Tue, Dec 18, 2018 at 4:46:09 PM
CMU + brick wall- brick is NOT bearing
Tue, Dec 22, 2009 at 3:16:30 PM
Brick or Stone Overhang
Tue, May 8, 2007 at 11:40:16 AM
Page generation time: 2.7689
