Forums >> Revit Building >> Technical Support >> Filled Regions in Detail Components
Fri, Jul 13, 2018 at 10:57:50 AM | Filled Regions in Detail Components
CKirivong
I have a filled region loaded into a detail component family that is transparent. I have the same filled region loaded into the project. The filled region acts transparent in the DC family however when I load it into the project it becomes opaque (even thought it is still noted as transparent). Has anyone else run into this?
Thanks!
Fri, Jul 13, 2018 at 1:20:45 PM | Filled Regions in Detail Components
The project RULES.  If any asset / material / region is defined in the project before a family is loaded, the project's settings always over-rule the family.
Mon, Jul 16, 2018 at 7:12:04 PM | Filled Regions in Detail Components
CKirivong
Understood, however I have the same filled region in the project that is transpartent. I loaded that transparent filled region into the detail component family and it is transparent in the family while I'm editing it. However, when I load it back into the project the filled region become opaque.
Any ideas?
Tue, Jul 17, 2018 at 2:01:35 PM | Filled Regions in Detail Components
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Any chance there's a 'masking region' at play in the family ? Or just rename the filled region to a unique name in the family (maybe even rename the family itself and reload it. If it's still opaque then the problem lies in the family somewhere.
Edited on: Tue, Jul 17, 2018 at 2:03:47 PM
Tue, Jul 17, 2018 at 9:19:34 PM | Filled Regions in Detail Components
CKirivong
No masking regions. I tried created both a new filled region and saving the detail component as a different family name. Neither of them worked. Thanks for the tips thought! If I change the Filled region pattern from solid light grey transparent (the one that won't show up transparent in the project) to a diagonal line transparent, that works. I may end up choosing a different filled region pattern, but it still bugs me that it won't work.
snap to filled regions in detail components
Tue, Jun 7, 2005 at 2:14:19 PM
Tue, Jun 19, 2012 at 1:53:08 PM
Tracing filled regions with linework
Tue, Mar 3, 2009 at 10:24:52 AM
Masking Regions and Filled Regions BEHIND 3D Objects
Wed, Aug 1, 2012 at 8:10:27 AM
Filled Regions and families
Sun, Mar 8, 2009 at 7:10:29 PM
Page generation time: 1.5500
