10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Roof Help
Revit 2017 - I took it from level 1 where I created a floor plan. The created a roof - it prompted to create on roof level. I said yes and then
the floor plan went ghosted and I used it to create the roof. It shows in 2d, elevations and section but does not show on the roof plan. What am I doing wrong. Any help will be appreciated. I havef read all the roof threads to see if I could figure it out but can.t - Thank you Byron
Try adjusting your view range - its not high enough to see the roof.
The view range button is ghosted and cannot change anything
Does your view have a view template? Turn that off.
No view template
Show us an image of your view properties similar to attached but large enough that we can read it.
Here you go
The view range is not ghosted.
Roof design problems |
Fri, Jul 9, 2010 at 7:30:00 AM
12
Additional Roof will not attach to original roof |
Fri, Jun 7, 2013 at 7:56:40 AM
problemed roof |
Fri, Mar 23, 2007 at 5:12:30 PM
Roof problems! |
Sun, Feb 1, 2004 at 7:26:42 PM
Joining a conical roof to a gable roof or other rectangular roof |
Tue, May 28, 2013 at 9:29:25 AM
