Forums >> General Discussion >> Wishlist >> Revit Dimension Straight Leader Line with Controllable Node at Elbow
Thu, Jul 12, 2018 at 12:32:47 PM | Revit Dimension Straight Leader Line with Controllable Node at Elbow
Shoeusc
I like that Revit has a Straight Leader Line for the linear dimension styles, however I wish that the control was easier. Currently it seems that you can only control the length of the elbow. Whereas leader lines for text and wall tags works differently (better). It would be great if it could have a controllable node at the elbow to make it easier to get a 90 degree elbow, etc for these dimension leaders. I can't find a way to make this family adjustment in the settings, am I missing something?
Dimension Leader
Mon, Sep 24, 2007 at 12:32:09 PM
Callout Leader Line Straightening After Placing
Fri, Jan 22, 2016 at 3:36:22 PM
offsetting node points..
Mon, Jan 25, 2010 at 9:31:03 AM
Can leaders and dimensions be modified
Mon, Dec 22, 2008 at 11:02:52 AM
diagonal to straight wall dimension.
Tue, May 26, 2015 at 8:45:43 AM
Page generation time: 3.0839
