Forums >> Revit Structure >> Technical Support >> What am I doing wrong?
Wed, Jul 11, 2018 at 10:17:48 AM | What am I doing wrong?
1bchristian
Revit 2017 - I have attached a file that shows my problems. The first is, the slab edge and slab will not join. The second is I try to show my brick ledge in plan and it will not unhide. Can some one tell me what I am doing wrong. Thank you -Byron
Thu, Jul 19, 2018 at 2:26:56 PM | What am I doing wrong?
sllana
5 Stars: 2 Votes
if i understood it well, the problem could be that that ledge is above the cut plane in the view range. But what for shure you did wrong is the attachment, there is no one.
Edited on: Thu, Jul 19, 2018 at 2:27:23 PM
What am I doing wrong? Metallic Paint??!!
Thu, May 19, 2011 at 5:31:01 AM
what is wrong with dimesions?
Fri, Jan 15, 2010 at 7:04:17 PM
after revit export to pdf the file is wrong scale
Sat, Nov 20, 2010 at 10:54:04 PM
Rendering the Wrong Material
Wed, Feb 18, 2009 at 8:53:57 AM
Brace goes Wrong?! wrong connections
Mon, Aug 31, 2020 at 3:06:09 PM
Page generation time: 0.8186
