Forums >> Revit Building >> Technical Support >> How to create recessed infills above windows on brick veneer?
Tue, Jul 10, 2018 at 6:10:55 PM | How to create recessed infills above windows on brick veneer?
SeanKirkland
Can anyone help me out here? I have tried spliting walls, using a stacked wall, etc but this takes so long.
I have also tried wall sweeps but you cannot changing the material to the surface above the window.
Searched high and low and cannot find a soloution. I have attached a coloured ArchiCAD file that does it at easy as an example.
Wed, Jul 11, 2018 at 1:14:42 AM | How to create recessed infills above windows on brick veneer?
tim123
4 Stars: 19 Votes
Not sure what you mean.  The image shows two windows with wall sweeps.  The material can be changed and the depth can be controlled.
Brick veneer stepping at alternate elevations
Wed, Aug 14, 2013 at 8:28:36 PM
How to make a recessed panel in a masonry wall
Fri, Oct 26, 2007 at 7:19:46 AM
Windows
Tue, May 31, 2011 at 9:46:12 AM
brick veneer window insertion question
Tue, Nov 23, 2004 at 4:28:49 PM
BRICK VENEER WALL
Fri, Jul 22, 2005 at 8:55:04 AM
Page generation time: 1.5377
