Forums >> Revit Building >> Technical Support >> double printing Revit 2018
Sat, Jul 7, 2018 at 10:25:27 PM | double printing Revit 2018
rgaaia
i am having an issue with double printing. when i choose 1 copy i get 2 copies of most but not all of my sheets! what can be causing this?
Mon, Jul 9, 2018 at 3:35:04 PM | double printing Revit 2018
dgcad
dgcad Avatar
3.5 Stars: 36 Votes
Just a shot in the dark . . . . make sure your default printer is NOT set to "Microsoft print to PDF" regardless of whwether or not you are using it. This setting causes all kinds of unexplanable printing errors. It should be removed because it's useless and comes with very limited sheet sizes and no means to create new sizes and for the most part just doesn't work.
Revit 2018 - Coordination Models and Printing to Vector
Fri, Apr 21, 2017 at 2:49:50 PM
Version 2018 - Printing Reference Planes / Lines
Fri, May 4, 2018 at 9:23:45 AM
Copying elements from old project to a new one in Revit 2018
Wed, Apr 11, 2018 at 3:32:49 PM
How to make double or tripple Andersen double-hung windows
Sun, Jan 11, 2009 at 12:38:51 PM
Hotgear for Revit 2018 and leater
Sat, Mar 14, 2020 at 3:15:26 PM
Page generation time: 1.8129
