Forums >> Revit Building >> Technical Support >> twisted objects
Tue, Aug 31, 2004 at 9:13:00 PM | twisted objects
laBOMBA
Hi, I am trying to make a tensile structure, but I'm having difficulties with making the shape of the sail. Does anybody know how I can make a surface which is curved in 2 ways?
Tue, Aug 31, 2004 at 10:32:57 PM | RE: twisted objects
Mr GG
3.5 Stars: 9 Votes
Have a look at this one in the gallery: http://revitcity.com/gallery.php?action=view&gallery_id=132 Doing tensile structures with Toposurface found under Site in Revit can also be a possibility. Or importing the sail as a 3D-dwg-file?
Wed, Sep 1, 2004 at 12:19:10 AM | RE: twisted objects
laBOMBA
thx Mr. GG It helps a bit. I'm just not sure how to draw 2 connected lines as a profile. Can you delete one after you finished? Or you need to make a void afterwards? I got some crazy architecture modelled in Rhino which I want to bring into Revit to see if the program can take really complex shapes. I'm not yet convinced that Revit can do these things easily. Maybe you have a better idea?
Wed, Sep 1, 2004 at 10:20:19 AM | RE: twisted objects
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
Use a blend... with curved profiles. Hopefully that will get you going in the right direction
Hiroshi Jacobs
The Catholic University of America
Wed, Sep 1, 2004 at 6:51:43 PM | RE: twisted objects
laBOMBA
cool, it works. But the blend needs to work with closed lines got to try some more things to see how i can apply materials to it and maybe get some windows or doors in. Lets say that I have a curved wall in 2 directions. Is it possible to make a curtain wall of it? Structurally spoken, it should be possible, its just very hard.
twisted/slope/curve roof
Thu, Oct 19, 2006 at 7:26:04 PM
twisted baluster family
Tue, Aug 2, 2005 at 8:16:59 AM
not sure.....
Thu, Feb 26, 2009 at 5:49:29 AM
Converting AutoCAD ACIS Objects (3D Solid) to Polymesh Objects
Fri, Oct 12, 2012 at 7:31:58 AM
How to create a twisted beam of light?
Sat, Sep 17, 2016 at 6:56:19 PM
Page generation time: 0.1046
