25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> How do you hide mass created in adaptive componnents?
0 Posts No Rating |
I've tried to create this thing in the video https://www.youtube.com/watch?v=erYMC9nJa74 but can't figure out how he managed to hide the mass.For example at 2:55 you can see he is hosting some patterns on the mass and made the mass innvisible.
I did get his file and turns out he simply uncheckerd mass from visible graphics but when I do the same nothing happens?
You can get his file from here http://buildz.blogspot.com/2010/09/making-dinosaur-bone.html.
I will also upload his my file here.
The mass created in Adaptive components is a Generic Model. Turn that category off.
0 Posts No Rating |
I already tried unchecking generic models form visible graphic,it hides both the mass aswell as the skeleton structure hosted on it.And if I select the mass and uncheck the visibility option from propertites than the mass still stays there.
I also tried to model the mass in conceptual mass and host the skeleton structure on it,that way the mass does becomes invisible if I uncheck mass from visible graphic leaving the skeleton behind but the downside is that I can't manipulate the shape of mass created in conceptual mass like howw I can in manipulate the mass in adaptive component family.
You might try to add Y/N parameter, and tied it to the visibility, such as assign the generic Model 1 to A, generic model 2 to B, then in the project you can turn them off and on.
Edited on: Mon, Jun 25, 2018 at 2:23:08 PM
0 Posts No Rating |
Yess,adding y/n visiblity paramter solved the problem.
Cut Adaptive Components [ 1 2 ] |
Thu, Jan 17, 2013 at 4:35:38 AM
18
adaptive components |
Fri, Jan 23, 2015 at 7:12:31 AM
Show user created dimensions within Adaptive Component in Sheets (2016) |
Fri, Jul 1, 2016 at 1:55:50 PM
Unable to load conceptual mass into project |
Fri, Sep 11, 2015 at 1:40:26 PM
Conceptual Mass Project Space Visibility |
Fri, Jul 15, 2011 at 1:46:11 PM
