Forums >> Revit Building >> Technical Support >> Printing
Mon, Jun 11, 2018 at 11:23:08 AM | Printing
1bchristian
I just upgraded t windows 10 anyone having problems printing with revit 2017 - Thanks Byron
Tue, Jun 12, 2018 at 1:01:08 AM | Printing
tim123
4 Stars: 19 Votes
You will need to be a bit more specific with this query.
Wed, Jun 13, 2018 at 3:02:42 PM | Printing
1bchristian
I upgraded to windows 10 using revit 2017. All my other softwares print with no problem even autocad 2018. But in Revit 2017 I select print and it will not let me use the setup, select, oreview, printing tips or help button. It seems to be a revit problem. has this happened to anyone else.
Thu, Jun 14, 2018 at 12:59:04 AM | Printing
tim123
4 Stars: 19 Votes
We had the issue with 2017 when we first used it with Windows 10, mainly with PDF's.  Installing the latest update sorted most of the issues.
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:01 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:15 AM
17
Printing Query
Wed, May 23, 2012 at 7:54:08 AM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Black lines printing grayscale in PDF
Fri, Oct 10, 2014 at 4:46:46 PM
Page generation time: 3.2081
