Forums >> Revit Systems >> Technical Support >> All my mechanical equipment is showing up on all the levels
Sat, Jun 9, 2018 at 5:53:16 AM | All my mechanical equipment is showing up on all the levels
kelasa
At work, I'm having my first opportunity at being the BIM lead on a project. I set up the Revit model. I feel like I missed a vital step in the process. Currently, all the Mechanical equipment which is only on two levels, is visible on all the levels. What can I do to limit the mechanical equipment view range to only the level that it's placed on?
Thank you for your time.
Mon, Jun 11, 2018 at 2:55:08 PM | All my mechanical equipment is showing up on all the levels
Please add more information.  Are the mechanical elements Revit or imported CAD modeling?
Mechanical Equipment with Electrical connections showing 0V
Mon, Oct 11, 2010 at 8:13:43 PM
Mechanical Equipment pipe connectors...
Tue, Nov 18, 2008 at 11:21:28 AM
Piping Medium Detail Issue at Mechanical Equipment Connection
Thu, Sep 27, 2012 at 3:45:11 PM
Object Style - Mechanical Equipment section workaround?
Wed, Jul 16, 2008 at 4:18:14 PM
Revit Mechanical Equipment question VAV unit question
Mon, Oct 24, 2016 at 4:17:00 PM
Page generation time: 0.6283
